How to Turn a Multiple Morph into One?
I created my morphs and renamed a few of them and after I saved them they turned into this.
Is it possible to make them become one morph?
I have already tried to completely delete them and then download them again
But after I went to daz again everything came back
  • Richard HaseltineRichard Haseltine Posts: 111,996
    You can acces them to change their labels by opening the Parameters pane option menu (the lined/hamburger button in the top corner) and turning off Consolidate Properties.
    Given the Sub Components tab it appears that these are not simply morphs in which case consolidating them into one would be tricky.
  • crosswindcrosswind Posts: 10,356
    Avoid giving the same Label to different properties... better add prefix or suffix to differentiate them.
    If you don't need a morph property any more, delete it from the data folder where its DSF file locates.
