Help Creating a Highway That Follows Terrain
Hi all,
I'm scripting a graphic novel version of a short story I published a few years back.  The opening panels are establishing shots of an East Tennessee landscape, with mountains in the background, farms and rolling hills foreground, and a road winding through it.  I'm having no problems creating everything else in Carrara or Infinito for Daz Studio, but I'm having trouble even finding a web tutorial that explains how to create a decently realistic winding road that follows the terrain (I say "decently" because I'll be processing the imgaes in Photoshop and inking them to give a sort of cell-shaded feel).
I'd far prefer modelling the road to adding it in Photoshop, as the panel sequence for the first page will be more or less like a storyboarded crane shot, with the camera lowering and pulling in.  Hand-drawing the road consistently from at least three different perspective points would be more difficult than modeling it (for me, anyway).
If someone has tried this, I would greatly appreciate you sharing your workflow for it.  It's very important to the story, which starts and ends with these landscape shots.
Thanks!
  • argus1000argus1000 Posts: 701
    Mark Bremmer has a tutorial called "Road on terrains" here: http://www.markbremmer.com/3Bpages/tutorials.html, Hope it works for you.
  • 3DAGE3DAGE Posts: 3,321
    HI :)
    It's not as easy as it sounds ,.. especially the part about the "decently realistic" ..that means detailed textures, and normally much more detailed than the overall terrain texture.
    you should have a look at howie's "Country Lane" series,... It sounds like that's what you need ready to roll
    http://www.daz3d.com/country-lane
    http://www.daz3d.com/country-lane-hedgerow
    http://www.daz3d.com/country-lane-2
    most of the objects and plants in those scenes can be moved, shuffled, to randomise within the replicators to personalise the scene.
    Alternatively,..
    You could use the 3D Paint functions to paint onto a model, or a terrain ,. Carrara's terrain editor also has a basic terrain painting function,(importing a greyscale image or height map is generally easier) ... but the terrain editor has some nice filters, such as Terrace or Plateau filters which can create step or level cut-in areas on the side of a slope if you just want a nice flat section of surface with a sceneic view.
    Mark Bremmer also had a tutorial on exporting terrain maps, editing in Photoshop and returning to Carrara's terrain
    Depending on the shot distance,. you could get away with a "painted on" road,. especially if you're post processing  as line art
    do you have a photo reference of what you looking to make?
    imagining would need mesh tweaking so cars dont slide sideways
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,804
    Shapemagic guy has roadmaker that works on heightmaps
    something like that would be good for dinosaur foot prints
  • That Other PersonaThat Other Persona Posts: 381
    edited January 2016
    Draping a road... Mark Bremmer's vid comes to mind, but that is an undertaking.
    A nice road building model set would be great to have in the store.  Straights, curves, up/down slope, etc.  Another set for highways.  I've seen them on other sites . . .  Then create the lanscape around the roads.
    I just tried making a simple curved road in a drawing app with a transparent background.  Used it on a plane in Carrara and it looked OK, but lacks depth.
    Post edited by That Other Persona on
    Hi all,
    Thanks!
    Maybe use something like Mark Bremmer's tutorial to create the more distant parts of the road and model the close up parts, including a bit that matches up with the terrain in the vertex modeler?
  • RoygeeRoygee Posts: 2,247
    There is a method I have used - simple, a bit fiddly, if Carrara doesn't crash during the process!
    Make a copy of the terrain and convert to other modeller - this is where it sometimes crashes.
    Take the copy into the vertex room and use a very clever function Carrara has - draw a curve along the surface of the terrain (this is the fiddly bit - you need to click on verts) where you want the road to be - if you do it carefully, the curve will conform to the surface.  Make a flattened rectangle to the width and depth of the road and do a path sweep (be sure to have the rectangle at 90 degrees to and positioned at the start of the curve- viola, a road which conforms to the surface!
    Delete the copy of the terrain.
    Sounds cool,
    never had it crash doing first step, do that often to make an invisble editable by deletion of bits terrain for surface replication,
    unless have my octane window open, believe it or not you can model in vertex room and watch it in real time render but that is indeed crashy
    edited January 2016
    this is probably straight out of mark Bremmer's tut, but this is how I would do it.
    Make a terrain
    convert it to an obj mesh
    export the materials - name the diffuse file 'terrain' - save it
    in photoshop make a new layer on the terrain image and draw the road in black with a soft brush
    put a white layer under this
    saves this as 'transmap'.psd
    go to the layer with the black road, make the edges hard with filter>threshold
    save this is "displacment" psd
    make another layer and make it the colour of your road - eg tarmac texture
    save this as 'road' psd
    go back into car
    in the shader room make your terrain object texture tree "Multichannel" (not terrain)
    use the displacment map in the displacment section of your this new terrain texture
    in the vertex room you tick smooth and give it a rendering level of two
    fine tune the softness of the 'diplacment map file until you get it right - try adding a little noise to it even in photoshop
    for the terrain texture use your orginal terrain.psd
    but instead of just a texture in the colour section use the operator 'mixer'
    source 1 will be your terrain.psd
    source 2 will be your be your 'road' psd
    blender will be your 'transmap.psd
    this will place your road texture in the right place
    soften the edges in photoshop even more to fine tune if necessary
    - when happpy with how it looks in Carrara export this as an obj again, tick 'convert procedural shaders to textures'
    in photoshop paint in the details you want - eg white lines on road, or graduations from tarmac to terrain
    save this out and use it as your terrain texture
    1201 x 900 - 324K
    Post edited by Headwax on
    here's a close up with a smooth factor of 3, i think you could get it a lot neater
    also a plainer jane one
    1933 x 900 - 472K
    1005 x 900 - 192K
    1005 x 900 - 192K
  • Thank you all so much for the suggestions and ideas.  I appreciate it!
