Texture Converter 2
if this is in the wrong forum or if it breaks the forums' rules, please delete this post.
Hi, I've just installed TC2 and V4A4 plugin, however when I try to access the program I get the following error: Runtime error: 13 Type mismatch.
any ideas on how to solve this? even the main website doesn't have answers... it's kinda frustrating.
any help is much appreciated.
  • Richard HaseltineRichard Haseltine Posts: 111,491
    Which version of WIndows do you have?
  • edited December 1969
    W7 x64, sry I forgot to mention this
  • vwranglervwrangler Posts: 5,048
    edited September 2012
    Does this happen on startup or when you try to convert a texture?
    If it happens on startup, I can't think of anything that might help, other than reinstalling the program. If it happens when you try to convert a texture however, judging from what you've said, the issue might be that you don't have plugins for both ends of the process.
    You say that you've installed the V4A4 plugin, so I assume that's what you're translating to -- you want a V4A4 compatible texture at the end of the process.
    The question is, what are you translating from? What is your source texture? If you're trying to convert a V3/A3/SP3 texture, you need to purchase that plugin as well. I know there are clothing converters out there that only require you to purchase the destination plugin, but in this case, you need to purchase both.
    Hope this is of some use.
    Post edited by vwrangler on
  • lexhajtoslexhajtos Posts: 2
    edited January 2013
    Hello ;)
    i just bought the TC 2 plug in with the TC2 - Second Life Avatar.
    but the TC2 - Second Life Avatar installer after download show 0 Ko ^^
    i have trying with other browser and on my laptot, no way :(
    i have submit on tiket but no reply :/
    someone can help me?
    i apologise for my horrible english ... i do my best :)
    1127 x 395 - 64K
    Post edited by lexhajtos on
    When did you submit the support ticket?
    yes but ... no reply :/
    What was the ticket number?
