Hair/Shader problem
So, in the image you can see the problem I am having, using the omni shader. Lights are pointlights/rectangle. First time seeing this, but I don't use the omni shader (if it actually is the problem) that much.
Thanks in advance, Linkin.
1082 x 1088 - 819K
  • linkinbnulinkinbnu Posts: 18
    edited July 2024
    I just found the error, lowered the render tesselation to 0, weird. I'll leave it here for info, and If anyone knows why this happens feel free to post.
    Linkin.
    Post edited by linkinbnu on
  • chevybabe25chevybabe25 Posts: 1,363
    The old hairs like that one there, are set to use a higher tesselation, before curves were introduced.  If you picked up my omni shader set in the store, there should be a preset that changes the tesselation over for you.
