Measure Metrics not showing on Daz Studio 4.22
I have Daz Studio 4.22 and installed Measure Metrics using DIM. However, the Measure Metrics doesn't show up on the plugins list. After digging, I now understand I need Daz Studio 4.6 and up to run it. Where can I find Daz Studio 4.6? Is there a way where I can run it on Daz Studio 4.22?
  • Richard HaseltineRichard Haseltine Posts: 111,715
    Are you sure you installed the Measure Metrics plug-in, not just the Figure metrics script which uses it? And is your Daz Studio the current version, assuming that Measure Metrics is a fresh download?
    Why would you want 4.6? You can get 4.5 with the SDK, since that is the minimum version for plug-ins in general, but other old versions are not generally available - certainly not that far back, which woudl fail to work correctly with a lot of more recent content. (If you are reading the numbers as decimals - don't, they are 4.x.x.x with each being a whole number, 6 is a long way before 22.)
  • akshatsonarakshatsonar Posts: 2
    edited July 2024
    I recently installed Daz Studio 4.22, DIM, and purchased and installed the Measure Metrics plugin (https://www.daz3d.com/measure-metrics-for-daz-studio). On DIM it shows me to install Figure Metrics for Daz Studio 4.6+ Content. Even after reinstalling everything Measure Metrics doesn't show in the Window>Panes section and also in the Help>About Installed Plugin section. Am I doing something wrong? I also installed Daz Studio 4.5 SDK but still, nothing shows.
    Post edited by akshatsonar on
  • LeanaLeana Posts: 13,572
    There are 2 parts to install, the actual Measure Metrics plugin and Figure Metrics content. Did you install both?
    You certainly don't list the plug-in (or the script, possibly - that package may just be the presets). Click Install Filters in the Ready To Download tab and make sure that plug-ins are selected.
    edited July 2024
    Plugins - you want the ones for your version(s) of DS - if you have the Public Build os DS (the beta) there will also be plug-in installers for that:
    • Measure Metrics for DAZ Studio 4.22+ (Win 64-bit)
    • Measure Metrics for DAZ Studio 4.22+ (Win 32-bit)
    • Measure Metrics for DAZ Studio 4.22+ (Mac 64-bit)
    • Measure Metrics for DAZ Studio 4.22+ (Mac 32-bit)
    Figure Metrics script and configuration
    • Figure Metrics for DAZ Studio 4.6+
    Figure Metrics presests and morphs
    • Figure Metrics for DAZ Studio 4.6+ Content
    See the file list here http://docs.daz3d.com/doku.php/public/read_me/index/16684/file_list
    edited July 2024
    Thank You, Richard and Leana! Measure Metrics now shows up. I only had downloaded the Figure Metrics file and once I opened Download Filters and selected plug-ins it showed me the Measure Metric file for download.
