Is there a way to set Daz to load with the Environment Map off by default
hellster90hellster90 Posts: 16
edited July 2024 in New Users
Is there a way to get Daz to have the Evironment Map turned off by default when it loads?, I'm using Daz 4.22 (Also tested in 4.21)
I have been using SY Sky System iRay for lighting in some scenes (outdoor), but it seems since it doesn't set an Environment Map, Daz will switch on the default one and it disables the SY lighting on loading the scene.
So if I wanted to use Render Queue etc it would mess up the lighting in the scenes.
Any help would be much appreciated.
I don't mind turning it on manually when I need it.
Post edited by hellster90 on
