Finding missing content files
Some of my content files are missing in the content library. I can find them using Explorer, they are in the right folders. But, when I search in DAZ they cannot be found. I have tried DB management, to get rid of orphaned file references, and then had it search for files on known directories, and still nothing. I know that its there somewhere, but how do I get DAZ to find these files? I also have folders in the DAZ studio section and in the Poser format sections, that are empty! No clue why the content disappeared. I thought those folders were supposed to remain as a file reference that mimicked my actual Library structure. I have DAZ 4.8, Win7/32-bit.  I have rebuilt my library 6 times now due to screwing up where i put things, or moving things, so this current installation is strictly working with the DIM, except for freebie content, from other sites, which I carefully put in the proper folders. Thanks.
  • What files, and where exactly are they? What is the path of the content directory that holds them?
    Can you post these 2 screenshots:
    1) In DS, Edit > Preferences > Content Library > Content Directory Manager, expand the "DAZ Studio Formats" and "Poser Formats"
    2) In DIM, on Ready to Install tab check the "Show Details" box in the lower right
  • Here are the two screen shots below. It is various files, some, for example: Like the DAZ Content File are empty, also, Like the DAZ Material File, are also all empty. Even though I can search in Explorer and find the files. Its random files, random places. I generally try to put DAZ files (Genesis, V4, M4, etc) files in My DAZ3d Library and Poser files (P1-5, V1-3, M1-3, Steph, Freak, Aiko, etc) in the Poser 5 Directory. But, when I search in DAZ, it often doesn't find files that I know that I installed.  I also included screen shots of the empty folders. I have changed it from searching files to searching the database, and vice versa, still with no luck. Thanks for the help.
    872 x 658 - 85K
    872 x 658 - 85K
    607 x 553 - 53K
    872 x 658 - 85K
    662 x 602 - 37K
    656 x 587 - 33K
    It looks like you've got things installed to the wrong place.  The folders you have under "DAZ Materials" are Poser-format files that are normally in Runtime:Libraries:Pose.  They won't show up outside of that structure.
  • Well, most of the stuff I installed with the DIM. The rest of the stuff I installed using the zip folders the author provided or the .exe that DAZ/Poser provided. And oddly, a lot of Poser material files are saved as Pz2 or pz3, rather than mc6 and such.  Also, if I categorize files, they sometimes disappear from the top level library and only appear in the My Content Library. And sometimes things disappear from the My Content Library. So, Where do I put them if they are in the wrong place? And how do I figure out which ones go where? Since as I said, I was using the installers they provided?
  • Make sure you are isntalling to the My DAZ 3D Library folder, not the My DAZ 3D Library\DAZ Content folder.
  • Thanks for the help, I have been installing to the My DAZ 3D folder, unless it was a runtime folder specifically. Then I copy the runtime folder directly to Either Poser 5 or to the DAZ 3D Library folder, depending on whether it is Genesis content or Legacy content. But, yes, its still a mess, and I don't know how to make it any better without breaking things. So, Such is life. Thanks again for your time.
    Make sure when you copy a Runtime folder that it is being merged with the existing Runtime -- if it ends up inside the existing Runtime it won't be found.
