Problem with dForce Hair and almost all Geoshells
In the past few days, I've found that dForce hair is unusable. It will show in texture shaded view and lock up or be transparent when switching to Iray. The shells problem is with all genitalia including the DAZ 3d basic version for all models (Genesis, G3/8/9). It appears as if it is not aligned with the mesh. Has anyone encountered this? And if so, have you found a fix?
  • Richard HaseltineRichard Haseltine Posts: 111,984
    What hair? Is it growing on areas of the base mesh thata re hidden by the graft? What tool is active?
  • crosswindcrosswind Posts: 10,356
    It sounds like a strand-based hair, better name it or post a screenshot ~
    The problem of shells is a separate issue ? If it looks like floating or something... did you by chance switch to other tools like Geometry Editor or Node Weight Brush ? Try presssing Alt Shift + U to see if there's any change...
