Missing Files - Outoftouch's new Turbulent Warrior hair
Maybe someone can help me get these files ??
Their missing from the zips i downloaded
Thanks
Tom
912 x 382 - 41K
912 x 371 - 33K
  • Richard HaseltineRichard Haseltine Posts: 111,715
    edited June 2024
    If they are missing and required then only Daz may provide them, please open a suport ticket. I just loaded the base hair and didn't get that prompt, however - what were you loading at the time? Edit: OK, it happens with the A version but not the B - I would suspect that may be a file error in the A version rather than actual missing files.
    I wasnt loading anthing ? I used DIM initially - then uninstalled and deletd - then attempted again - then did a manual download and install in my library - same issue - thanks
    Thats correct - it also throws that error when you go to apply materials
  • PlantPlant Posts: 127
    you are not alone i have the same problem
  • artxtapartxtap Posts: 186
    don't have this product - so this just a [wild] guess
    search for those files in the duf and see if those files have a
    "//" at the start of the file path
    it should be a
    "/" ............................................not //
    it should be a
    If the path starts with data, or Runtime for textues, it probably isn't that issue - though it could be mid-path.
  • Same problem here. Reinstalling did not help. I will try contacting OOT and point him/her to this thread!
    edited June 2024
    There hasn't been an update so reisntalling won't yet help.
  • There is an update of the product now. It solved the problem for me. blush
