Can Poses Foil a dForce Simulation?
Without going into product details, I rendered two images using the same dForce-enabled outfit (a matching jacket and skirt) worn by the same G8F character. In the first image, the character is standing and the simulation worked a treat. In the second, the character was seated and the simulation produced a messy blob. I took care to turn off simulation on hair and every other article of clothing; only the jacket and skirt were visible in simulation. Has anyone had a similar experience? Thanks to one and all.
  • LeanaLeana Posts: 13,642
    edited June 2024
    Pose and surrounding items (I imagine she was sitting on something) can definitely be a factor, as dForce doesn't like intersecting items.
    Sitting poses are typically a case where I would consider using an animation to get the simulation right.
    Post edited by Leana on
  • crosswindcrosswind Posts: 10,356
    edited June 2024
    For the figure with a sitting pose, did you check the option "Start Bones From Memorized Pose" in Simulation Settings pane, before Simulation ? or used a Timeline to Simulation ?
    If a figure has a sitting, lying, crouching, jumping... etc. pose, better use one of the above options...
    Post edited by crosswind on
  • contedesfeescontedesfees Posts: 299
    Thank you, Leana and crosswind. I do very much appreciate your replies.
