Custom heels offset from foot after transferring rigging
I followed the attached procedure to the letter, and many others, and have found that the shoes are always offset to the side once finally set to fit. Online others have reported this (the third photo), but no resolution. I had to create the foot pose around which to model, and this is usually suggested by all of these tutorials, so that can't be the culprit?
Any ideas?
2765 x 540 - 123K
1048 x 763 - 33K
1041 x 1310 - 951K
1807 x 1255 - 2M
  • crosswindcrosswind Posts: 10,358
    edited June 2024
    You didn't make the shoes on a Base figure but a character, correct ?  If so, you need to re-import the shoes OBJ as a delta to update the AutoFollow FBM in the hidden properties of the shoes.
    As per the standard procedure, make shoes on Genesis x Base figure rather than a character...
    Besides, also check pjcm (cbs on G9) morphs in hidden properties of the shoes, you need to fixe them as well with such a Feet Pose.
    Post edited by crosswind on
