Rendering with Strata Design 3D
I recently upgraded my Strata Design 3D software to version 8.1 and also picked up an integrated version of HDR Light Studio (which sits at version 4).
Exported Victoria 7 HD (still need to tweak multipliers to get a proper sized model). Had to play a bit with the materials. So far, focused mostly on the eyes and did apply the normal maps to the face and lips. In HDR Light Studio, I set up a primary softbox, a window and a small light to add extra specular highlights to the eyes. I used their Radiosity render engine to produce the final image.
One thing I haven't played with yet is attempting to layer the skin textures and see what may result from that. Going to experiment with the SSS maps primarily.
There are two key things I like about this renderer. First, is performance. The attached took just under 11 minutes on a 2012 3GHz 12-core Mac Pro. Total RAM consumption by the renderer was just under 5 GB. Second, the resultant image was rendered in 32-bits per channel and so easy to export either an OpenEXR image or 16-bit per channel PSD.
Has anyone had success in exporting scenes and used other software to generate renders?
