Was "Show Asset in Mapped Folder" Removed from Content Library Search Results?
When I ran a search in the Content Library tab, I used to be able to right-click on one of the search results and select "Show Asset in: Mapped folder" and go directly to the location of that product in the library. That option no longer shows up; now "Show Asset" options only list Smart Content, Virtual Folder, and Products.
Was that option removed in 4.22? I finally upgraded a couple days ago.
If I right-click on items on the Smart Content tab, I do get the option to "Show Asset in: Content Library > Mapped Folder". So, I can select "Show Asset in: Smart Content > Files" to go to the item on the Smart Tab, then select "Show Asset in: Content Library > Mapped Folder" to reach the directory, but it is annoying to have to use two steps to accomplish what I used to be able to do in one step.
So, was the option actually removed, or am I missing something?
  • barbultbarbult Posts: 27,631
    Try the Virtual Folder option. For some reason, that shows up instead of Mapped Folder, but for me, it seem to do the same thing.
  • EscribanoEscribano Posts: 109
    Thanks! I had been hesitant to click that since it it did not sound even remotely like what I was looking for :)
  • crosswindcrosswind Posts: 10,344
    If you search or filter in Smart Content, it always shows "...Mapped Folder" but if you do so in Content Library, it always shows "...Virtual Folder".
    "Virtual Folder" used to be associated with Daz Connect folders. Now it seems to be used for all content folders, but not consistently throughout the interface. I don't know if that name change is a bug that hasn't been fixed or if it was intentional. In Smart Content, still uses the term "Mapped Folder". I asked about htis inconsistency a long time ago, but I got no answer.
    560 x 430 - 69K
    770 x 383 - 72K
  • Richard HaseltineRichard Haseltine Posts: 111,851
    Virtual Folder should be the Daz Connect container (because it is an aggregation of the al the /data/cloud/1_SKU/ folders rather than a real location on disc) while mapped folders are the real content directories for content installed manually or through DIM/Daz Central. I am not sure why it would give inconsistent labels like that.
    I think that inconsistency first showed up in the release (beta?) when Daz changed the File/New to that unpopular dialog with advertising. I asked about it at the time. It was not explained.
    I'm not 100% sure but IIRC, "virtual folder" had been there for quite a while before the above-mentioned version was released.
  • DoctorJellybeanDoctorJellybean Posts: 10,193
    It has been fixed
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#4_22_1_152
    It has been fixed
    Thanks! I hate inconsistency.
