[Solved] How to use the VBDS thingies in Arcane VFX ?
ElorElor Posts: 4,232
Edit: Solution is to use Daz 4.22 at least.
Original problem:
Hello,
I'm speaking about this product, Arcane VFX, by @KindredArts.
If it's useful, I did my test on Daz 4.21.0.5 on my Mac, so everything is done with the CPU.
I loaded the various VDBs props, who are supposed to be on fire, but I'm likely missing something because instead of a cool looking fire portal, I have a brown sand storm:
I tried to play with the various settings, but at best, I was able to change the color of the smoke but I was not able to get the fire effect at the base of the portal crying
800 x 800 - 106K
Post edited by Elor on
  • KindredArtsKindredArts Posts: 1,356
    I hate to be the bearer of bad news, but you might have to update. The newest version is 4.22.0.16 and they should be a-ok in there. I've just double checked on a clean install and it's running.
  • GordigGordig Posts: 10,821
    Try updating your Default Resources. VDB emission was a more recent addition.
  • Richard HaseltineRichard Haseltine Posts: 111,875
    If you are using too old a version of Daz Studio, and are reluctant to update, you could use the Beta (free from the store) alongside your current, older, geeeral release.
  • nemesis10nemesis10 Posts: 4,036
    edited June 2024
    I started a render but life happened so I had to stop it prematurely but here is the center of that portal
    1319 x 1073 - 4M
    Post edited by nemesis10 on
    If only "compatible software" listed the minimum required version of DS for that particular product, rather than the current version.
  • ElorElor Posts: 4,232
    Thank you all for your answers smiley
    Oh, don't be, it's actually a good new: I have the beta alongside the 4.21 version, and using it, the fire portal was indeed on fire.
