Shoes Fit Error
how can i fix this error?
Post edited by mmetehanbaydar_77b0078348 on
  • felisfelis Posts: 6,642
    Which character is it?
  • crosswindcrosswind Posts: 10,358
    edited June 2024
    In most cases, the distortion is caused by the full body morph or partial body morph. Reason: It's not possible for the vendor to make and fix AutoFollow FBM of all characters.
    You may try:
    - Select shoes first. Tick Show Hidden Properties... in Parameters pane (from that hamburger menu in the upper left corner).
    - Slect Currently Used, look for the character's body morph property in the parameter list, reduce or zero the value.
    It might not be 100% perfect but it's the easiest way... If you know a modeling / sculpting software like Blender, the best way is to export the shoes and fix the AutoFollow FBM morph on the shoes.
    2560 x 1392 - 416K
    2560 x 1392 - 419K
    Post edited by crosswind on
