Female warrior muscle
xavierator
Dear,
Can I get a similar base as attached image using "Genesis 9 female" and adding this reference ?
https://www.daz3d.com/massive-morphs-for-genesis-9
I mean getting more marked muscles than using only the basic female, especially the biceps.
Thanks, Xavi
966 x 628 - 108K
Post edited by xavierator on
I don't have the product so no idea (even if there is no reason for it not to work on Base Femine).
@RawArt created a support thread for that product and is regurlarly active on the forum:
https://www.daz3d.com/forums/discussion/625646/
You can use the massive morph set for that...it can add just muscle definition if you want, or you can dial up the muscles as big as you want.
The only thing to keep in mind is that this works full body and is not broken down into individual muscle groups, there are other sets that do that, mine is made for quick and simple bulking up
This is a pretty good product. Here's some examples of Jenni 9 with the female morphs included. Her base form, then with the massive muscle morph, then with the bodybuilder and then female hero (with also muscle added).
The Hero will increase height, hands and feet, too. Now THAT's a hero!
Perfect, I will try the RawArt reference soon.
Thanks, Xavi
Not sure if you are interested in other options too if so Freja 9 and 9 has a bulk option that seems a bit more like the 3d figure you posted
I've personally had a lot of luck using Freja 8 and 9 for bulking up characters along with https://www.daz3d.com/sy-intense-muscle-genesis-8-81-and-9 . Using Freja 9 and the other I mentioned I created a character almost as buff as the one in your image fairly easily.
And Freja 8 plus another buff female asian daz original character whose name I am forgetting for this one: (You mentioned Gen9 and since Freja works for both thought I would show Freja's bulk dialed in a bit more than my Gen9 character above)
Good luck with whatever assets you end up getting. There are so many good ones for dialing in that I hope you get one that works for what you need :)
Dear,
I just check Freja 8 (https://www.daz3d.com/freja-8), and I would like to know the meaning of this term:
In fact, I don't need an extra muscles, for this bust, I only need to enhanced a little bit the biceps, without exaggerating or showing the veins.
Do you think that I can get this needs only with Freja 8 an it's "muscle contraction added" ?
https://www.daz3d.com/cdn-cgi/image/width=200,height=200,fit=cover/https://gcdn.daz3d.com/p/73503/i/freja-8-01-daz3d.jpg
My mission is to print a 3D bust.
Thanks
Muscle flexing is a standard feature of Genesis 8. I do not believe that Freja has any additional capabilities in this respect.
Muscle flexing is NOT a standard feature of G8; JCMs make bends look more natural and realistic. There are many products that can add musculature and flexion morphs.
While comparatively basic, the Base Flexions controller on Genesis 8 is a standard feature that did not exist on Genesis 3. Check the file path of the controller in its properties - it's found in the Base folder.
The text being referenced exists on all G8 core characters, right back to Victoria 8: https://www.daz3d.com/victoria-8
Freja 9 has a great buff build, and it looks like she was specifically designed for that viking look and style (as evidenced by her bundles). However, don't discount Kara 9's, Cheyenne 9's and Zahara 9's buff builds!
