change the path of several Morphs at the same time in parameter settings?
Hello everyone
Do you know if it is possible to change the path of several Morph at the same time in parameter settings?
I have several dozen Morph to transfer to another folder but doing it one by one makes me lose a lot of time...
Thank you
  • crosswindcrosswind Posts: 10,249
    Which path...?  the path in Parameter Settings or the path (folders on your disk) where morph files (DSF) locate ? They're different things.
    If you mean the former, turn on Edit Mode in Parameters pane, multi-select the morphs, in RMB menu : Set - Property Group.
    If you mean the latter, just physically move the DSF files from current folder to the destination folder. F2 - Clear DSON Cache. Then reload Genesis figure.
  • food.plus13food.plus13 Posts: 133
    Thank you very much, I was talking about the 1st case... until now I did it one by one... it's crazy!
    For the physical folders I don't really understand... do I have to press the F2 key? I always thought that to change the physical folder I had to save the Morphs in another folder.
    Yep,but you can also manually move the files. Clear cache in F2 is to assure a fresh load of morphs. It's a safer way.
    When I do F2 I have this window and I can't find "DSON Cache"
    497 x 606 - 38K
  • Richard HaseltineRichard Haseltine Posts: 111,359
    That is the scripting pane - you need the main window's Edit>Preferences.
    Perfect thank you very much
