Trouble with DzPopupMenu
kabexefkabexef Posts: 96
In DS 4.21 I wanted to use DzPopupMenu.insertTextSubmenuItem to create a submenu within the popup and got the error 'TypeError: cannot call insertTextSubmenuItem(): argument 2 has unknown type `QMenu*' (register the type with qScriptRegisterMetaType())'.
    wPopupMenu = new DzPopupMenu(dialog);
    var wSubPopUp = new DzPopupMenu(dialog);     wSubPopUp.insertTextItem("Title", 0);
    wPopupMenu.insertTextItem("None", 0);     wPopupMenu.insertTextSubmenuItem("Product", wSubPopUp, 1, 1);
Did I use it wrong?
Post edited by kabexef on
  • Richard HaseltineRichard Haseltine Posts: 111,315
    It is correct - it wants text, hence the method name, and you are giving it the menu object.
  • kabexefkabexef Posts: 96
    edited May 2024
    Sorry, but I can't figure it out ...
    wSubPopUp.insertTextItem("Title");
    wPopupMenu.insertTextItem("None");
    wPopupMenu.insertTextSubmenuItem("Product"); will result in
    SyntaxError: too few arguments in call to insertTextSubmenuItem(); candidates are insertTextSubmenuItem(QString,QMenu*) insertTextSubmenuItem(QString,QMenu*,int) insertTextSubmenuItem(QString,QMenu*,int,int)
    The method therefore requires a QMenu* object as the second argument.
    wPopupMenu.insertTextSubmenuItem("Product", wSubPopUp); and
    wPopupMenu.insertTextSubmenuItem("Product", "wSubPopUp.exec"); and
    wPopupMenu.insertTextSubmenuItem("Product", "wSubPopUp"); result in
    wPopupMenu.insertTextSubmenuItem("Product", wSubPopUp.exec); won't throw an error but also won't show a submenu.
    Is there a small, working example somewhere?
    Sorry, I was misreading
    I am told you need to use wSubPopUp.getWidget()
    wPopupMenu.insertTextSubmenuItem( "Product", wSubPopUp.getWidget(), 1, 1 );
    It works :-). Thank a lot!
    Keep an eye on the change log as this has been chnaged to remove the need for the getWidget() call - and there will be a sample showing how it works.
