Iray viewport and actual render look different in 4.22
Hello, I just upgraded to 4.22 and noticed that the iray viewport looks different than the actual render. This isn't an ideal workflow if the viewport doesn't display accurately.
My PC has 128gb or RAM and an RTX 3090. Everything was running smoothly on 4.20. How can I fix this?
1479 x 1016 - 572K
  • barbultbarbult Posts: 27,499
    Do you have both preview and render set to Photoreal, or is the viewport in Interactive?
  • crosswindcrosswind Posts: 10,249
    Nvidia Iray preview in Viewport may have different settings in Drawstyle Settings. Open Drawstyle Settings pane, check if the settings there are as same as the ones in Render Settings, especially the properties:
    - Draw Mode (Render Mode)
    - Caustic Sampler
    - Guided Sampling
    - Spectral related properties
  • EichtamEichtam Posts: 9
    It was set to interactive on the Drawstyle Settings pane. I never encountered this on previous installs as both the render setting and the draw style settings were set to photoreal. Thanks so much for your help!
