UltraScenery2 - Realistic Landscape System Pane is Missing / Landscape Generator not working !
I´am sorry to complain, but the new Ultra Scenery2 product isn´t working !
Well first i thought, i would be my error, because i installed it manually. So i uninstalled all manually again, and used the Daz Install Manager for installation. But again there the Ultra Scenery 2 don´t show up in the pane and can´t be used. Only the trees, rocks, gras, etc... of the product is available in the Smart Content, but you can´t generate Landscapes. So i uninstalled the product with Daz Install Manager again, deleted the files and started the whole installation again.
Same result !
Meanwhile i did this 4 times and even uninstalled and installed Daz Studio new. But still the Plugin for starting Ultrascenery 2 doesn´t work and you can´t generate landscape with it. Well i´am really sorry to complain, because i really love the Ultra Scenery Products, i use very much and also bought all of them.
  • SimonJMSimonJM Posts: 6,101
    I had something similar - a cycle of Daz Studio fixed the issue.
  • Thanks for you advice SimonJM but unfortunally it didn´t work either !
    So i tried again to uninstall and install the product with Daz Install Manager, still the same problem. Also i tried an older version of Daz, which also had no success. And finally i uninstalled Daz Studio 4.22 again, installed it new and updated everything. But still the Plugin don´t appear in the pane section and you can´t start the Landscape Generator for UltraScenery.
    But i think i know the problem meanwhile ! So the product was sold with an error file ....
    1876 x 932 - 380K
  • Richard HaseltineRichard Haseltine Posts: 111,688
    Did you check it was listed in Help>About Installed Plug-ins, and what its status was? I haven't yet purchased so I don't know if it needs a serial number - if it has a box next to the name with a placeholder then it does need a serial number entered (from your account's serial numbers page, I expect).
  • ShimrianShimrian Posts: 590
    edited May 2024
    Edit: more update on thread so my original update already answered
    If you're still have issues, try asking in the commercial product thread: https://www.daz3d.com/forums/discussion/636346/ultrascenery-new-er-territory-commercial#latest
    Post edited by Shimrian on
  • Dear Richard Haseltine,
    thank you for your answer !
    No, there is no serial number activation required. So I think this product was unfortunally really released with an major error this time.
    At least at "About Installed Plug-ins" there is no error or Serialkey query shown.
    It´s really a pitty.  So i really love the "Ultra Scenery" Products and never had problems with them. At least till now !
    1402 x 850 - 189K
    Your screenshot shows UltraSceneryXT, which is a different product. Didn't find UltraScenery 2 in there or anything that could be it.
  • Yes that is the Problem PerttiA !
    It´s installed and i can use the trees, stones, gras, etc. in the Smart Content. But it´s not show in the Plugins and i can´t start the Landscape generator.
    I think it´s an error in the Win 64 file !
    So UltraSceneryXT is also a Plugin, but don´t make any problems !
    1881 x 945 - 394K
    Are you installing the plug-in (the Win64 package) through DIM? If not it is likely to end up placed incorrectly. As I said in the main thread (please take the rest of the discussion there) plug-in do not install the way content does, Ultra Scenere 2 has both contetn and plug-in.
  • Problem solved !
    Thank to you Richard Haseltine and Doctor Jellybean.
    So the Plugins must really installed at the Harddrive where the main Programm of Daz3D is installed ! So because of my manual installation i have also the Plugins of the Ultra Scenery Products on other harddrives installed, but Daz3D works only with those at the main directory. So probably i had "UltrasceneryXT" in past also installed by the DAZ Install Manager, which back then still choosed the drive where the Daz3D main Program was installed. I had changed that. After i looked in the "about installed plugins" again with details, everything became clear. So i changed it back and tried to install again.
    Now it runs !
    Thank you very much Richard Haseltine and Doctor Jellybean.
    1194 x 714 - 174K
