Long render time
Hi, I have been using daz now on and off for about a month. I am by all means a newbie and I wonder if it's normal (with iray) to be on 0% after 2hours with a Titan X. If it isn't does anyone know how I can fix it?
I Render in 16:9 1080p with a medium threshold 2048 and a high threshold 4096.
Thanks in advance!
    That is not normal...and usually indicates a 'stuck' render.
    Are all the materials, for everything in the scene, actually Iray materials?
    Which version of Studio?
  • version 4.8 and I'm 99% certain that all materials are Iray. Will dubblecheck just in case
  • just dubble checked and for good mesures applyed iray base shader on everything and still the same results. And I can see it doing iray itirations but after the first 2 minutes it seems like the rendered image doesn't change anymore
  • Having the same problems, and after 2 hours it just stops rendering.
    Two hours is the default time limit...
  • fastbike1fastbike1 Posts: 4,079
    Just in case, is the Titan X selected in the Render Settings? I ask because the graphics card doesn't always get selected by default (the first time you use it).
