dForce AK Knight Hair for Genesis 9, 8, and 8.1 Male colours not working
Hi I have just purchased the Knights Hair product and installed using DIM, it all works fine but the materials option is loading when selected but the hair colour does not change from the base grey colour using the provided material buttons.
does not show any change in colour in any of the view options - what am I doing wrong, everything else in DAZ works fine and has no issues. Have un-installed and re-installed now - no change?
Same with both GF8 and G9....
any suggestions?
  • crosswindcrosswind Posts: 10,263
    edited May 2024
    It is a strand-based hair using Omni Hair shader, so if you want to see the color changing, you need to press Ctrl + 0 to switch to Nvidia Iray drawstyle...
    2027 x 1390 - 2M
    2560 x 1392 - 2M
    Post edited by crosswind on
  • jedihaggisjedihaggis Posts: 5
    Yep I was already in NVIDIA IRAY nad no change.
    this is the screen grab in NVIDIA just after I had selected Color 14 (highlighted in yellow) - no change from the grey.
    when selected the material is loaded but when the viewer catches up - no change.
    1810 x 971 - 791K
    What is your DS version? And have you had the latest Default Resources product updated? You can go to Surfaces pane, check if you can see Omni shader there.
    running DAZ 4.22.01,
    when I installed the Knights hair it did add a further default resources to the install which I agreed to. I also have the Revelations Omni shader pack installed?
    It does say Omnihair Art Ken (MDL) at top of the panel?
    435 x 647 - 45K
    Yes, that is correct. And what is your Nvidia Driver version ? Update it to the latest Studio version...
