Is this the way to adjust earring?
Hello DAZ,
I had been fixed this issue by moving an ear long time ago, but now, it occurs again and this time, adjusting an ear does not help much
First picture is the position of the Left earring before render
Second picture is when render is finished (earring mislocated)
So, I looked around the forum and the answer is SUB-D, after a few tested
The method :
1. turn figure resolution to base
2. adjust the earring to wanted position
3. turn figure resolution to high resolution (third picture)
4. Rendered (fourth picture)
Please, let me know if there is another ways or how you guys doing?
476 x 755 - 202K
162 x 293 - 50K
203 x 264 - 53K
233 x 464 - 163K
  • crosswindcrosswind Posts: 10,285
    edited May 2024
    I would say that should be the issue comes from the earring's parent - that Rigid Follow Node... You can drag the earing figure from the rigid follow node to Left Ear node and try tweaking it again.
    To me, the rigid follow node for this earring is not really necessary let alone whether it was correctly set or not...
    In my exp., if a rigid follow node is unproperly set, there'll be such a similar issue... i.e. the children under the rigid follow node will be "misplaced" when redering with SubD...
    518 x 1294 - 130K
    Post edited by crosswind on
  • Hi, I have some dForce earring and necklace sets. When I simulate, the necklace works fine. But the earrings don’t simulate. I get a pop-up saying there's no dForce surface to simulate. If I manually add a dForce Modifier: Dynamic Surface to the earrings, they explode during simulation. I didn’t change any settings. The product name already includes “dForce Earrings,” so I expected it to work out of the box. Can someone please help me fix this? I just want the earrings to hang and move naturally.
