Is there any way to remove tan lines for Babina 8?
I like Babina 8's skin except for her tan lines. Is there any way to remove those tan lines?
  • Matt_CastleMatt_Castle Posts: 3,251
    I loaded the base and translucency colour maps into Photoshop, set up an adjustment layer that matched the tone, then painted a mask over the tan lines.
    You don't need to get the mask perfect - skin isn't perfect as it is, so as long as the brush doesn't have a hard edge, you won't notice the transition afterwards.
  • kyoto kidkyoto kid Posts: 42,408
    ..I imagine you could use any other similar skin from a G8 character. or create one that is a close match without the lines if you have Skin Builder for G8.
  • dan_thomasdan_thomas Posts: 107
    Thanks for your suggestions, guys.
    I found that Zelera 8's body skin matches Babina 8's head skin with little tweaks.
