How to change simulation visibiliy of all objects at once?
James
The purpose is to make simulation faster, So I want to make the visibility off and I will only turn on all the necessary objects.
If you in scene tab select all those you want not to participate in simulation, and in Parameters Options enable Consolidate Properties, you can set them all to Off at the same time.
Are you aware that you can select those you want to participate in simulation and 'simulate selected'?
Strongly recommend this product firstly... now it has a big discount : https://www.daz3d.com/dforce-companion
If you don't want to own such a product to expedite your dForce sim. process, you still don't have to toggle Visible in Simulation properties...
Hold Ctrl key, firstly select the figure, then select the garments you want to simulate in Scene pane. Then right-click on Simulation Settings pane tab, click Simulate Selected.
Also see http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/simulating/simulate_selected_group/start
