Exporting FBX Files
Is there a special order or system for exporting DAZ Figures from DAZ Studio to Vue. I have tried it a couple of times and DAZ Studio just hangs there! Cheers
  • crosswindcrosswind Posts: 10,313
    What did you export that made DS hang ? And also, try with DS Public Build in which FBX export function has been much improved, and try with 2020 Binary format
  • Many thanks for your reply.It was a Genesis 8 Male in Wet Weather Gear Purchased from holding a set of Binoculars for my submarine in Vue! Ido not know which binary I used. Iwill try again using 2020 Binary! Cheers
  • I tried again. My figure was imported into Vue, but not the pose and prop binoculars or textures.I checked everything necessary for the export! obj exports ok with the pose but not with textures! Cheers
    1stly, export to FBX with the settings in screenshot 1... I don't use and have Vue. Here's an example of importing FBX into Blender. It should be almost the same... You should get the pose, texture, etc. in Vue.
    However, FBX format (as well as OBJ format) can just export Diffuse maps... you have to manually assign other texture maps yourself if there's any...
    2021 x 1393 - 761K
    2560 x 1392 - 1M
