Tinting Iray Lights
FyreHeartFyreHeart Posts: 32
edited January 2016 in New Users
I use tinted lights regularly to affect the mood of my scene, (see Evac! in my gallery for the most obvious example) but when I render in Iray, the light tints are ignored.
If I wanted to render the real-world equivalent of a light with a red gel in Iray, how would I do that?
Thanks.
Post edited by FyreHeart on
  • You can tint lights in Iray - what type of light are you using?
  • prixatprixat Posts: 1,618
    edited January 2016
    I have a red gel setup and a sample scene available in this thread:
    http://www.daz3d.com/forums/discussion/comment/863845/#Comment_863845
    Post edited by prixat on
  • FyreHeartFyreHeart Posts: 32
    edited January 2016
    I used spots. When I render in 3Delight, the lighting comes out right, but when I switch over to Iray, the exposure stays the same but all the lighting effects are gone. What am I missing?
    Edit: Here's a link to my image: http://www.daz3d.com/gallery/#images/96510/
    The same model with no changes rendered in Iray comes out without the bright spot out the window and with no light tints.
    Thanks.
  • PetercatPetercat Posts: 2,322
    Thanks.
    Select the light, then go to the Surfaces tab, Editor section, go down to Emissive Color, click on that to set the color. Luminance adjusts the brightness.
