Animate2 aniblocks - cannot access
I don't seem to be able to access the ani-block submenu in amimate - or it appears but evaporates when I try to select. Is there an update to animate? Will 4.9 work better?
I thought I had the same problem. I previously slid the undocked Animate window to my second monitor. The ani-block menu won't open there. It only opens if I have the pane placed over the main DAZ window. Also, sometimes it appears for a moment and disappears. That's because it's gone behind the Animate window. I can slide the Animate window sideways to get to the menu. But the menu is almost worthless. If I click in it to make it the active window, it selects whatever it's on. It won't scroll for me no matter what I do, and I can't nav to directories other than the main animate folder in the library. If my custom aniblocks are elsewhere, I can't get to them.
