Shift select not functional in DS 4.8 import of .obj sequence
I have imported an Obj sequence from Marvellous Designer and when I try to select shift (I want obj 2 through end sequence) the only response is selecting a single file - Ctrl +A also won't work. Any ideas on what is going on?
nothing is going on in that I have never been able to import more than one OBJ at a time and never found a way to do it. I have found that to minimie the workflow is to just to drag and drop, from the folder to the DS viewport window, one obj at a time.
mCasual has this script that may be of some help...
https://sites.google.com/site/mcasualsdazscripts4/mcjloadmanyobj
sweet thanks mjc...I should remember to look over there first. :)
I thought he had an obj sequence importer, too...but I couldn't find it.
OK my stupidity. DS is smart - the sequence needed to be imported using morph loader pro and I was trying to use morph loader advanced. DS knows enough it seems that it cannot allow multiple .obj's - so select shift is disabled. Just in case anyone interested in using dynamic clothing from MD to Poser see - fantastic stuff -
How to export animations from DAZ Studio to Marvelous Designer and back
The WP Guru
arrr that is what was missing, you using Morph Loader....cool that you got it sorted though. :)
