Toon Generations Mega-Bundle for Genesis 8 Male(s) and Female(s)
I paid a lot of money for this bundle https://www.daz3d.com/toon-generations-mega-bundle-for-genesis-8-males-and-females even though I already owned https://www.daz3d.com/toon-generations-4-mega-bundle-for-genesis-8 purely because it stated:
  • Individual dials for head and body shapes in case you wish to use them seperately
Where are these dials? I want to use the body with an anime head from https://www.daz3d.com/anime-faces-for-genesis-8-female. As I previousl said. I PAID A LOT OF MONEY for this product and to add insult to injury, it was on a masive sale TWO hours after I bought it and I can't find the option that had me purchase this product.
Most vendors will have "add body, remove body. Add head, remove head. This product DOES NOT. I have spent so much time scrolling though the various "morph" options in the shaping and Parameter tabs it is not funny, but is very stressful. Just trying to find what has been advertised in the product description. If something is adveretised in the product description, IT SHOULD BE EASY TO FIND.
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Have you tried typing Toon into the filter field in the Parameters pane? How did you install? Do the separate items (clothes and props) load without errors?
  • NorthOf45NorthOf45 Posts: 5,896
    This product works a little differently (so does Toon Generations 4). As Richard said, type in "Toon" into the Parameter's filter box. Start with  Actor-People-Stylized-Toon Generations. You will find "Toon Gen (3DU) Overall Strength". You need to dial this in to use the other controls for Toon Gen. (Not to be confused with "Enable TG4"). It will add a certain age setting by default, which controls the head and body settings. You can override them with their individual controls in other groups.
    Go to Actor-Full Body-People-Stylized and dial in the Toon Gen (3DU) Body settings you want. Similarly, go to Actor-Head-People-Stylized and dial in the Toon Gen (3DU) Head settings you want (in your case all 0.0 %). Then you can add your Anime heads.
  • drucdruc Posts: 500
    Thank you. Where I was going wrong was loading the toon character from the People/Genesis 8 Female/Characters/3DUniverse etc. All the toon options were set to zero in the parameters or shaping tabs. I just tried with an un-modified G8F and did the search on toons as I had previously. I dialed up the toon strenght the 100% and it also dialled up the mature head to 100%. If you load the toon character from the character folder, the head options are all 0%
    That solved the issue.
    Glad it worked out. I found it confusing to use at first...
