G3F nipples inferior to G2F
wheels0132wheels0132 Posts: 27
edited January 2016 in The Commons
I have shape shift and breast control for both G2F and G3F. G3F is supposed to have a more realistic appearance than G2F because it's newer and has more polygons, etc. The problem I'm encountering is that the G3F nipples take on a "tee-pee" shape rather than a "pencil eraser" shape when even a little bit erect. This looks bad. One of the sliders for G2F breast control is "Nipple Base." This control reduces the base of the nipple so that the shape can be manipulated into a more realistic look. Is there a reason that G3F doesn't have this, but the older generation does?
Because of this, I've stopped using G3F for anything nude which is a real shame. They are now solely used for fully clothed figures only.
Post edited by wheels0132 on
    Genesis 3 Female has few polygons that Genesis 2 Female and that is why the nipples don't look as good.  G3F has an HD morph for the mouth it should of had one for the nipples too.
  • nicsttnicstt Posts: 11,715
    Don't you mean inner-anantomical elements associated with the upper-anatomical elements? :)
    But yes, a nipple-effect when wearing clothes can take some tweakage.
  • McGyverMcGyver Posts: 7,102
    Ah, the "nipple-effect"... One of the most distracting side effects of faster than light travel... But Einstein warned us, did he not?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,506
    I am more worried about tweakage on my nipples when wearing clothesangry
  • I am more worried about tweakage on my nipples when wearing clothesangry
    I've already resigned myself to the fact that if my models are wearing clothes, it's gotta be a pretty warm day! There can be only very minimal "pokie"! surprise
  • cosmo71cosmo71 Posts: 3,609
    it is not just the nipples, the whole breast/chest area is not very good.
    cosmo71 said:
    it is not just the nipples, the whole breast/chest area is not very good and I really do not get it, why they reduce polygons everytime they create a new figure. On breasts it is so that the morphs you have for shape and posing do not fit to the mesh because of the less polygons.
  • jakkujakku Posts: 91
    edited January 2016
    If you have Tara & Sachra HD for Victoria 7, load your figure, go to parameters tab and make sure you have it set to show hidden, then dial standard DAZ nipples, search for Tara Nipples HD click the small chain next to the lock, heart and cog of the upper right corner of the morph dial. Now dial the morph. Only tried it with the DAZ standard nipple morph, but it looks extremely realistic, very detailed, seriously.
    Edit: Try setting the Subd level to 4 in the viewport to see what I mean.
    Post edited by jakku on
    prolly means g3m has similar deficiency
  • Zev0Zev0 Posts: 7,123
    edited January 2016
    G3F has 2 or 3 less poly edge loops on the nipples than G2F, meaning G2F's nipples at same Sub-D level are more detailed since G3F has less polygons to work with. However G3F's breast polygons gives better movement. With HD morphs you can get that nipple detail back on G3F, depending on the HD morph. Personally I don't find this a huge issue, because when you apply textures that have decent bump or normal details, you hardly notice the difference unless the nipple is right in your face. But yes, they could have left those extra loops on G3F for a bit more detail when not using HD morphs...
    942 x 781 - 227K
    Post edited by Zev0 on
  • L'AdairL'Adair Posts: 9,479
    angel Maybe they'll put those loops back in for G4... devil
  • This sound like a good case for a free geomorph upgrade. This should be something that can be added if you need it. Just like the genitals.
  • Oso3DOso3D Posts: 15,116
    Now I'm envisioning prehensile nipples.
    prehensile
    I had to google this. Quite an interesting visual I'm left with when combined with nipples. o_O
  • isidornisidorn Posts: 1,601
    Pixolygon said:
    prehensile
    Me too...
    But surely there must be some hentai out there already covering that?
  • bytescapesbytescapes Posts: 1,932
    isidorn said:
    Pixolygon said:
    prehensile
    Me too...
    I am so not Googling to find out. Because I'm pretty sure that I'm not ready for whatever would be returned by a Google search for "prehensile nipple hentai". In fact, I venture to suggest that none of us are. But you know it has to exist. Because Rule 34.
    You know, it occurs to me that with the Singers of Chzor, I could probably make a picture along those lines.
    I don't WANT to, but I could.
    Click if you dare
    Well, there is way to get "good working" nipples but for that you have to have zev0`s breast control. With some of the breast control morphs and the original g3F morphs you can get some good results but you have to edit the paremeter limits or better check limits off.
  • isidorn said:
    Pixolygon said:
    prehensile
    Me too...
    Okay, I either have to stop reading the forums or stop looking things up because, no, I was not ready for that.  blush   I have a hard time refusing dares, too.  I wish I had in this case.  Good thing I'm not easily embarrassed as I would never surf the web if I did.  I sort of knew what prehensile meant, but had never thought to relate that to, well, that!  And, hentai was a new word for me.  I hadn't ever heard of Rule 34 either so I had to look that up, too.  I'm betting if I ask my DH, though, he's probably heard of it.  Considering what I write in my spare time, I didn't think I was that sheltered. surprise
