IPR renders fine one day.. not the next
Hi
I'm new to Daz (4.8) and I've spent the last three weeks getting to know the programe.
I use the aux viewport's IPR feature all the time. The other day I rendered an image and everything was fine. The next day I worked with the same scene but the IPR didn't work. Neither did spot rendering. A normal render works just fine it's only the IPR and spot. I use 3Delight.
I thought it had something to do with that specific scene but it was the same with several other scenes. Even simple setups with only one figure takes longer than it used to (but does work).
I've tried to rule out what the problem could be but it's hard to figure out. UberInvironment doesn't seem to be the problem. Neither does hair. And even if those things has something to do with it, it's still weird that I haven't had problems before yesterday. Also it uses 100% of my CPU when trying to render.
I checked the log and this seems to be the problem:
Rendering IPR Image WARNING: QColor::setHsv: HSV parameters out of range WARNING: QColor::setHsv: HSV parameters out of range WARNING: QColor::setHsv: HSV parameters out of range WARNING: QColor::setHsv: HSV parameters out of range Finished IPR Render Created RenderCacheBlock
I don't know what exactly it means. Tried googling but only few results popped up and no explanation as to what could cause it or how to fix it.
I spend the entire day trying to figure this out and now I give up.
Any of you clever people out there know what this is about?
Thanks in advance
Simon
PS: trying to render made my computer crash minutes ago while writing this. So this is the second time creating this thread.
Computer specs:
Toshiba model: Satellite L50D-A-10D
Windows 10
Processor - AMD A6-534M with Radeon(tm) HD Graphics, 2200 Mhz, 2 Cure(s), 2 Logical processors.
Memory - 6,0 GB DDR3
Why is it that when you've spent an entire day and the next morning, trying to solve a problem it suddenly goes away when you post a help thread?
For some reason my IPR works just fine now. I haven't made any changes whatsoever.
I still don't consider this problem resolved since I don't understand what happened or how it got rectified so I would still like to hear if anybody knows what this was all about?
Nope.. the problem is back :(
Any ideas?
Does it work if you set the 3Delight render settings to default?
No it's the same :/
It goes on and off. Sometimes it works and sometimes it doesn't. Luckily my computer renders pretty fast so I don't really need the aux viewport for it but it would be nice to have the IPR on.
