Will Dynamic Clothing Control help with leg poke through?
Not only help but will it make it easy to bring the dress back over the leg so there will be no poke through or... yes it can but there is a steep learning curve and until I learn how to use it good it I would not get good results or...no it will not correct things like leg poke through a dress for example as shown in the image attached
I do imagine that this only works on dynamic clothing, if that is true is there a way to make clothes that were not made dynamic convered into dynamic clothing?
https://www.daz3d.com/dynamic-clothing-control
thanks for the help
975 x 832 - 366K
  • BejaymacBejaymac Posts: 2,014
    edited May 2024
    You already have the basic version of that plugin, it comes as part of the default install for DS4.
    However it only works on OptiTex dynamic clothing, and is completely useless for Dforce or any other system.
    Post edited by Bejaymac on
  • Richard HaseltineRichard Haseltine Posts: 112,009
    Dynamic Clothing Control gives access to editing settings for OptiTex clothing, it doesn't add major new features.
  • VicSVicS Posts: 1,273
    So it will not work well with poke through such as the leg correct? Do not buy, ok, thanks
