Where do I buy this complete character?
Drogo Nazhur
I know where to buy the character but where do I get the outfits and the hair?
Drogo Nazhur
let's start with the hair: https://www.daz3d.com/deck-hand-hair-for-genesis-3-and-8-males
One piece used was https://www.daz3d.com/dforce-royal-fantasy-outfit-for-genesis-8-males
I suspect that the boots and truncks are https://www.daz3d.com/m3du-warrior-outfit-for-genesis-9 + a hair shader (probably copied from one of the other surfaces
One of the belts is https://www.daz3d.com/dforce-roar-armor-outfit-for-genesis-9
I think the white body suit is just a textured geoshell, the sword is from the Roar armor set, I don't recognize off the top of my head what the halter is but it looks easy enough to juryrig with some judicious transparency mapping, a bump map and normal and a texture. The chest cross looks like a decal.
thank you but will this work on G9 without an auto fit?
thank you. much appreciate it
If you fit it to G9 you will trigger autofit.
If you don't wan't autofit, you can just manually adjust the hair to the character and parent to the head.
And it autofits beautifully....
