i want to color effect but i can't.
I bought sci-fi effect and loaded it into daz3d. On the pre-render, the colors that work well come out, but on the renders, all the effects come out in black.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    Which effect? Is it made for the render engine you are using - Iray, 3Delight, Filament?
  • lilweeplilweep Posts: 2,872
    You genuinely feel you provided enough info in op?
  • chris-2599934chris-2599934 Posts: 1,975
    Is this the product you're talking about? https://www.daz3d.com/iray-scifi-vfx-kit
    It's hard to offer any help without more information
  • edited May 2024
    https://www.daz3d.com/fantasy-and-sci-fi-effects oh, I attached the picture but It was didn't. I bought this.
    Post edited by coolcool0131_eea6a807 on
    You need to set the Diffuse colour to white, Poser doesn't multiply the ambient colour by the diffuse (so it can be used as a glow) but DS does, or Delight does (so it behaves as a cheap way to have a genral lighting, without having to use an environment map). This is likely to be an issue with all effects that pre-date Iray (usally an SKU lower than 20,000 or so).
  • edited May 2024
    oh! laser is perfectly done! thank you for help
