Just updated to 4.21 How do I get my "style" back
Hi,
Just updated to 4.21. Everything is now white except for the viewport.
How do I get it back to the darker syle?
Can I enlarge the text?
Cheerio   lululee
  • felisfelis Posts: 6,592
    If you go to Windows > Style > Select Style.
  • lululee1lululee1 Posts: 346
    Hi, if i go there nothing will show up.
    Cheerio
    lululee
    Is your layout some whitish style?
    It might be that Daz Studio was running while you udgraded, and then the installation will be corrupt.
    You should then make sure Daz Studio is fully shut down, then uninstall, and then reinstall.
  • Richard HaseltineRichard Haseltine Posts: 111,835
    All white generally means that DS was running when the new version was installed, probably in the background, shutting down. You do need to reinstall the application (and the Dynamic Clothing Control plug-in, if you have that).
    Hi,
     Yes, it is white.
    Can you tell me how to uninstall.
    I don't see anything to uninstall in the folder.
    Cheerio
    lululee
    I can't uninstall it from "settings" because it does not show up in my "settings".
    Cheerio
    lululee
    Assuming you installed through Install Manager you uninstall from there too, but if you right-click on its entry in the Installed tab there should be a reinstall option if you didn't have DIM set to delete packages after installation.
    Daz Central asked me if I wanted to install it.
    I did not uninstall but did install it from DC.
    It is now seems to be running properly.
    Will it be ok if I did it this way?
    Cheerio
    lululee
    Ah, if you are stil using Daz Central then that does give fewer options (and doesn't keep the packages for reinstallation).
    Hi,
    Thanks so much for all of your help.
    All is well and it is working just fine.
    Cheerio
    lululee
