Account Fail to login-PostgreSQL error
I keep having a PostgreSQL error...and fail to login to account problem.....
This has occured even with the firewall completely OFF.....
Ive tried every fix findable on the web...except....
I dont know how to determin which port the setting should be on....I cant change the port number if I dont know where to set it to......
  • Richard HaseltineRichard Haseltine Posts: 111,399
    If the port number (which is a pretty arbitrary number, as long as you don't go into the range of reserved values like 80 for the Internet Protocol) can't be changed then that suggests there is an issue with the path to the settings file. Does your Windows username, in C:/Users/, have any characters thata re not part of the base, US character set?
  • lstubbs2lstubbs2 Posts: 51
    The entire Applications\data\Daz 3d file structure ends up on Drive D;....
    I need to find where it is supposed to be on drive C: in a normal install...
    It seems that it is supposed to be in the AppData file.
    Thesettings will be in the AppData regardless, though the database itself may not.
    %appdata%/daz 3d/cms/
    will get you there, the question is about the characters used in the username folder, which will be in that path when it is expanded to show the actual location of the appdata folder.
