looking for a good morph tutorial for a hood
Hi All.
I am looking for a good morph tutorial
i want to make the hood from Vitruvian Exosuit Female
look as if it has been pulled back, still staying around the neck just pulled back off the head and hanging/rolled around the neck.
Any recommendations?
  • felisfelis Posts: 6,597
    edited April 2024
    Making a morph for a hood, should include that the hood  would drape.
    It would be best to done by simulating, as it is hard to model convincenly.
    You also should be aware of, if you apply a morph the hood will still move with head movements, as the vertexes belongs to the head.
    That said, is it something like this you are after?
    It is done purely by dForce simulation. A dForce simulation can also be exported and then imported as a morph (should be done on base character).
    1600 x 1600 - 2M
    Post edited by felis on
  • Nice work Felis.
    that is almost what I am looking for. but i what it to be higher up the neck and to drap jfrom just under the jawline.
    so it still looks fitted around the neck.
    edited April 2024
    I had added a dForce weightmap, and you can adjust the areas affected by dForce.
    Although it might take some fidling to get to the specific result you are after.
    1600 x 1600 - 2M
  • thanks I will have a play with it
