Saving pose presets
I'm trying to save pose presets for the DAZ horse 2 tail. I go through the usual pose saving procedure but what ends up is that the tail will move but the hair still sticks straight out and doesn't follow the tail. What is the fix for this, please!
...and how do I search in these discussion forums, it used to be easy. I don't see a search box anymore.
x593
    For the hair on the tail ... as I recall those were morphs so you'd have to adjust the morphs for the pose.
    Searching in here ... a lot of us use Google and for keywords add "Daz, forum," possibly a topic keyword to narrow down the search results.
  • nicsttnicstt Posts: 11,715
    try shapeing instead of poseing. I haven't got it, but could be an answer.
    Alternatively, save as a subset?
  • The pose preset works fine with the mane hair. It seems odd that when the tail is moved in DAZ the hair follows but when it's saved as a pose it doesn't..
  • I did find that if I do the horse pose and then add the tail hair it will conform to the tail. It won't morph though. At least it follows the tail!
  • duh, me not so schmart. When I added the tail it fit to the main and not the tail. Problem solved..
    Glad to hear you solved the problem :-)
