Tulip hair?
Bought Tulip hair Can anybody tell me what the diference between Tulip hair WM and tuliphair is and what does the back filler do?
  • TaozTaoz Posts: 10,343
    edited January 2016
    The Doc page says this:
    The Hair comes in two varieties: with and without bones.
    • The one with bones, will closely follow Genesis head movements (like a hood) so you will not experience the hair poking through her body, however, the morphs and movements are also affected, and therefore will not flow as naturally as they should. You should use this when you don't want to tweak the hair at all and with more static setups.
    • The one without bones will still move with Genesis, but the length of the hair will not stick to her neck and shoulder. This means the morphs are free to move at their best, you may need more tweaking, but you have much more control.
    I'd guess WM means Weight Mapped then.
    The page also has a link to a PDF tutorial which explains about the back filler.
    http://docs.daz3d.com/doku.php/public/read_me/index/22210/start
    I bought it myself a while ago, used the opportunity to test it, it seems to take a very long time to render by default.
    Post edited by Taoz on
