How do you convert an emissive object into not being emissive anymore
How do you convert an emissive object into not being emissive anymore?
  • Richard HaseltineRichard Haseltine Posts: 111,371
    For Iray set the Emission Colour to black, in the Editor tab of the Surfaces pane with the object and its emissive surfaces selected.
  • VicSVicS Posts: 1,273
    I was asking becuase I made the bulbs emissive and Im rendering the smae scene min 3DL and sunce tyhye were made emissive there is no longer the setting for ambient so I cannot make the bulb appear that it is on, so if possible, would like to set it back to to the bulbs original properties in oreder to get the ambient slider there
  • LeanaLeana Posts: 13,502
    You will need to apply a 3DL standard shader to the surface if you want it to have surface properties for 3DL.
    Thanks Leana, that's a life saver
