Use Morph G8 by converting G8 to G9?
Hi everyone,
I own several G8 custom Morphs and want to use them with G9.
1/ Do you know if "Figure Converter for Genesis 9" does what I want to do?
2/ If not, do you know a way to do what I want to do?
Thanks
Moved to Techncial Help
Yes it does.
As an alternative, without using any product, you also can use the "fit suit method" to make the conversion. - https://youtu.be/jROlY34tNNU?si=-p0VmuIUA72ZCR20
Thank you for answering, the Yes is for "Figure Converter for Genesis 9"?
I will try the alternative method
