Huge problem to get rid of much noise, even on full render cycle
launoklaunok Posts: 807
edited April 2024 in Daz Studio Discussion
I am trying to get rid of heavy noise, even on light areas.  Normally dark areas shows noise more but not on my scene.
I even tried this denoise filtering to switch parts on:
- Firefly Filter Enable (ON)
- Post Denoiser Enable (ON)
- Post Denoiser Available (ON)
Post Denoiser Start Iteration: 8
It don't work at all.  After 2 hours render the noise is still much visible.
Attached cutout of image after full render time!
I have no idea why it's like this.  Are there other ways to make the noise less?
Any help is much appreciated.
Laura
586 x 586 - 114K
Post edited by launok on
    Which GPU, how much VRAM it has and how much RAM does your computer have?
  • Richard HaseltineRichard Haseltine Posts: 111,371
    and which GPU driver do you have?
    Check the log (View>Troubleshooting>View Log File) for messages relating to your render.
  • launoklaunok Posts: 807
    edited April 2024
    I am not good with these.  I checked on Taskbar.  Someone told me to look it up there.
    I have 16 GB ram memory
    GPU 0 shows 7,9 mem = (Intel(R) UHD Graphics 620)
    GPU 1 shows 9,9 mem = (Nvidia GeForce MX130)
    VRAM, where is it showing?
    edited April 2024
    Will check it out this evening with a friend who knows more than myself.
    GPU 0 (Intel(R) UHD Graphics 620)
    GPU 1 (Nvidia GeForce MX130)
    It looks like your MX130 has either 2GB's or 4GB's of VRAM (memory) and neither is enough for rendering Iray.
    The Intel UHD graphics is not supported for Iray.
    Is this a laptop or desktop computer?
    edited April 2024
    It's a HP Laptop Corei7, got it in 2021 I think.
    Peter, my friend, suggested I make spotrenders of parts that has much noise on changing settings and do postwork in Affinity Photo.
    The progressive rendering was on:
    Max samples = 5000
    Max time = 7200    Why it stopped exactly after 2 hrs.
    I need to higher this.  I have never used this before, in fact don't know much about render settings.
    I put as test it to 8000 for max samples and 10000 for max time.  Spotrender now after 40 minutes start to work a bit with less noise but still busy.
    Disable Rendering Quality and set Max samples and Max time to something like 50000.
    Your computer cannot render Iray on GPU, so you are rendering on CPU, which is glacially slow (hours, many of them)
    When I had an 4GB Nvidia card, I used to render over night.
