Problem applying a preset after converting clothes from G9 to G8
Hi everyone
I'm using the script "Lali's Seamless Pantyhose Classic + Low for Genesis 9" to convert G9 to G8 garments.
It works pretty well but when I want to change the color (preset) I get this error "An error occurred while reading the file, see the log file for more details."
Do you know a solution because it's not possible to convert presets?
Here are the contents of the log file:
2024-04-21 12:23:12.474 [INFO] :: Prepare asset load (merge): /People/Genesis 9/Clothing/Lali Kamala/Lali's Nylon/Lali's Seamless/LSP Low Mats/Red.duf
2024-04-21 12:23:12.474 [INFO] :: Locking viewport redraw...
2024-04-21 12:23:12.474 [INFO] :: Viewport redraw locked.
2024-04-21 12:23:12.557 [VERBOSE] :: Native format content directories: 2
2024-04-21 12:23:12.558 [VERBOSE] :: Poser format content directories: 2
2024-04-21 12:23:12.558 [VERBOSE] :: Other import format content directories: 0
2024-04-21 12:23:12.558 [INFO] :: Begin asset load (merge): /People/Genesis 9/Clothing/Lali Kamala/Lali's Nylon/Lali's Seamless/LSP Low Mats/Red.duf
2024-04-21 12:23:12.651 [INFO] :: Determining missing assets...
2024-04-21 12:23:12.792 [WARNING] :: Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2024-04-21 12:23:12.792 [WARNING] :: Error loading asset: D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 9/Clothing/Lali Kamala/Lali's Nylon/Lali's Seamless/LSP Low Mats/Red.duf
Operation failed
2024-04-21 12:23:12.880 [INFO] :: Unlocking viewport redraw...
2024-04-21 12:23:12.880 [INFO] :: Viewport redraw unlocked.
  • felisfelis Posts: 6,503
    It is a hieracical material preset.
    And with such it will look at the root node, and if autofitted the root node will have changed from G9 to G8, and the material load will fail.
    You could save it as ordinary material preset, when loaded on G9, or load it on G9, change textures and then fit to G8.
  • food.plus13food.plus13 Posts: 133
    Ok thanks, but if I save it as an ordinary material preset, when it's loaded on G9 it won't fit G8...
