Best way to fix skin textures from old figure?
mike9mike9 Posts: 69
edited January 2016 in New Users
I have a skin texture with patterns for Genesis 1 I would like to use with Victoria 6. It works fine with the Genesis 1 figure but with Victoria 6 the texture doen't fit correctly. I tried to change the "UV Set" option for the skin but none of the available additional options "Base Female", "Victoria 4" or "Victoria 5" creates the error less fit I get when using the Genesis 1 figure. My next approach was to adjust the textures with a graphic editing software but after trying a couple hours it seems rather difficult to get decent results without knowing exactly where and how big a gap is as well as how the next texture connects. Is there an easy way to edit the textures similar to gimp/photoshop (brush tools) but while the texture is on the figure or are there other ways to fix this?
Post edited by mike9 on
  • What is the UV Set when the textures are on, and fit, Genesis? Which UV Sets do you have for Genesis?
  • mike9mike9 Posts: 69
    "Genesis Female" is the UV Set working with Genesis but for Victoria 6 its not listed as option.
  • Well, there isn't a Genesis 6 (yet awhile). Do you have one of the UV Sets for Genesis that you also have for Genesis 2 Female?
  • Probably,through experimentation,you can try using the Genesis female 2's uv sets with Victoria 6. Results are mostly non-predictable though.
    Good luck!
    edited January 2016
    I can select the UV Set "Victoria 4" with both figures but the the skin texture doesn't fit with the Genesis 1 figure if Victoria 4 UV Set is selected. Is there a way to transfer the skin texture from the working Genesis 1 UV format to the Victoria 4 UV Set?
  • Richard HaseltineRichard Haseltine Posts: 111,363
    edited January 2016
    Yes, which is why I was asking if you had a common set between Genesis and Genesis 2 Female. You can use the map Transfer tool, available in the Surfces pane option menu (the lined button in the top corner, or right-click the tab) to do the conversion. This video describes the steps, though you can ignore the opening section about loading a UV set from an OBJ since you already have the UV sets loaded:
    (Click to get the YouTube play button, then click again to play.)
    edited January 2016
    Ok I got it working with the video. I can convert now from Genesis to Victoria 4 and from there to Victoria 6. If at one point a compatible UV Set for Victoria 6 + 7 gets available I should be even able to use the skin with Victoria 7. This helps me a lot. Thank you for the help.
    That is one thing that will never happen (it is a physical impossiblity)...but there are methods of converting to G3 from eariler generations.
    http://www.daz3d.com/forums/discussion/59665/tutorial-converting-textures-from-gen2-to-gen3/p1
    edited January 2016
    That method looks also good. As of now I'm missing one or two alternative daz figures with Genesis 3 to switch. But in a couple months it will probably be different and I will experiment with Genesis 3. Its good to know there is alrady a way to do it. Thanks for the link.
    edited January 2016
    This is a freebie V4 skin texture converted to G3F...
    800 x 1000 - 169K
    Post edited by mjc1016 on
    Is this without the Tex_Converter_Prep morph? The texture conversion helper file from the link has only morphs for G2 and G3.
    I did it in two steps...from V4 to G2F, then from that to G3F.
