Soft hair above forehead
Do you know how to add soft hairs like when you pulled your hair to the back. I just need to show a little bit, cos the head is covered in hijab.
  • Depending on what you're wanting, it might be easier to use postwork in photoshop or another photo editor.
    In software you could use strand based hair.
    Select item to apply hair to, then, Create>New strand based hair.
    Another option would be to use an existing hair with Sickleyields hat an hair helper. Only drawback with this product, you'll need to get one for each base figure you might use.
    There are also various partial hair products, such as biscuts partial hair fronts.
    If the hijab is worn for religious reasons, I don't think showing hair is the way to go.
  • JamesJames Posts: 1,191
    @barbult
    In real life, there are people who really make it tight - no hair showing, other keep it loose - allowing some part of the hair still appear.
