Can not reinstall DIM
With a recent upgrade to Windows 10 started having problems with DIM.   Decided to uninstall it and Daz and start over in order to move my library off C drive.
Only problem is that DAZ3DIM will not install.  I've used Advanced Revo Uninstaller to maker certain I got rid of Daz and Dim files, but when I open the Daz3dim exe file I get the msg to allow it to make changes to my computer, I click yes and . . . nothing.  I try opening as admin, same results.  I turned off all firewalls and threat protection no change.  Tried using the Windows install helper, nothing.  Also tried running exe in compatibiliy with Windows 7 which I upgraded from, still no joy.  At this point I'm at my wits end.
Has anybody else had this problem?
  • Richard HaseltineRichard Haseltine Posts: 112,009
    So is the instalaltion failing or is it not running after installation? Have you tried setting a different destination path if it is not installing at all?
