Gun GR15 for Genesis 3 Females questions
Does anyone have the Gun GR15 for Genesis 3 Females and can double check something for me?
http://www.daz3d.com/gun-gr15-for-genesis-3-female-s
There are Iray mats for the gun - but I noticed that when I apply the Iray mats, some of the surfaces are NOT iray settings, they are actually the normal 3delight settings.
Also in some of the promos there is a red beam coming out of the gun - they show in the in-program icons too. Is that just a promo look or is there something that is supposed to work on the gun when using it?
  • SimonJMSimonJM Posts: 6,100
    Yes, the Iray texture sets for the gun load both Iray and DAZ default shaders.
    As for the beam - click down the bone hierarchy (you have hip with sight and ray bones).  Select ray and in parameters you'll see a 'Ray Length' setting which will extend the beam/ray.
    oh WOW!!! Thank you SimonJM!! I NEVER even noticed that ray LOL!!!!
    Is it normal to have ds default shaders mixed wiht iray shaders tho on a product, when using Iray?
    I noticed the same thing being mentioend in a thread on another product and the PA said that the conversion process did a jod job withthe 3Delight textures, and from teh textures involved with the gun suspect the same thing here.
    As far as the ray goes, well that was just bloody-mindeness on my behalf!  This is one of the may products I have that I have never used, so I was curious and having looked at the material zones was struck by the ones called Red1, Red2 and Red3.  I have seen flames, etc., been controlled by a parameter dial so had a look at the base node, then I checked 'within' working on the bassi that the 'morphs' do not laways appear on the base node, saw the Ray bone and .. well, voila!
  • KA1KA1 Posts: 1,012
    Incredibly useful thread to find, I'm shortly coming up to some renders I'll need the beam for, I was prepared to create my own!!! Thanks for the tips folks :)
