Changing diffuse color
I am trying to change the difuse color for an outfit in the surfaces tab.  When I click browse to find my selection for the file change, nothing changes.  Any thought as to why and how to fix it?
thanks
Nat
  • I can't seem to set the image map.  It just doesn't change the image.
    More information would be helpful.
    Is this perchance an image you just edited? D/S has a cache so unless a newly made over image is given a different name, it will keep loading the old version.
    Some know how to clear the cache in an up and running D/S, that doesn't seem to work over here, so the other way is to close and open D/S and reload the items - or as above, simply rename the new file.
  • KindredArtsKindredArts Posts: 1,364
    You can hit ctrl-i to refresh the cached image, but it doesn't work all the time i've noticed. As patience said, You are probably best saving the scene and re-opening.
  • barbultbarbult Posts: 27,657
    edited December 2015
    Are you working on a Mac computer? I have seen two other threads that describe a similar problem, and both users were using a Mac, with DS 4.9, I think.
    http://www.daz3d.com/forums/discussion/comment/973382#Comment_973382
    Post edited by barbult on
  • nicsttnicstt Posts: 11,715
    TY must try this; I usually rename.
  • Thanks.  I am renaming but nothing happens and I do have the latest mac 4.9
    Might help people help you if you posted a screen grab of exactly where it is you are browsing for your image from, etc.
     The "call for" is a square button beside the color bar on the Surfaces Tab.
  • natclarkenatclarke Posts: 79
    edited January 2016
    All sorted.  I now drag and drop the image and it works rather than trying to find it and select.
    Post edited by natclarke on
