Moving "green gizmo" with Joint Editor
Is there any way to move the “green gizmo” with the Joint Editor by coordinates? Sometime the green gizmo is so far away from its object that, by the time I zoom out to see them both, the green gizmo is just a tiny dot. Using multiple viewports helps, but its still cumbersome to move the gizmo bit by bit by bit.
  • felisfelis Posts: 6,502
    I assume you are talking about the origin - if you go into Joint Editor tool?
    If so you can open Tool Settings and type in the values.
  • tubbesingtubbesing Posts: 56
    Thanks, that did it.
